2 members (Nick in Manitou, 2-Ton), 333 guests, and 8 robots.
Topics128,159
Posts1,057,039
Members48,460
#385071 03/08/2008 2:41 AM
Apprentice
Apprentice
Could anyone come up with the distance from the bottom of the frame under the cab to the pavement of a stock height 56 TF 1/2 ton? I'm working on a 56 3/4 ton that will have a 79 Firebird front subframe and rear end from the same car.
I bought the 56 as a basket case and have no way of establishing the 'normal original' ride height.
Any help or ideas appreciated.
Bob
I got about 18" on mine. With the front clip you're planning to use, stock hight won't be easy to acheive, unless you offset the front stub to compenasate. The axle centerline is much higher on the Firebird frame than it is on a truck frame.
Bill Burmeister
I'm changing springs so just made this measurement. My 58 Burb is right in line with what Longbox55 has. Before changing springs it measured 17.5 inches with fairly tall 235/75/15 tires.
Apprentice
Apprentice
Thanks for the replies and the info.
My plan is to use a 2" spacer between the bottom of the TF frame and the rear horns of the TA subframe. Should look something like this: (not mine)
http://img.photobucket.com/albums/v246/rbachman/FiftySix%20Chevy%20PU/TF80TAClip.jpg
It appears the top of the TF frame is flush with the top of the TA subframe.
Bob
That looks like it will help some, but it'll still sit lower than stock.
Bill Burmeister
