2 members (Gdads51, 68ironhead), 174 guests, and 0 robots.
Topics128,110
Posts1,056,251
Members48,437
#384596 03/07/2008 3:41 AM
am building an "origi rod" out of my 46 1/2t pu and want to keep the parts near the 50's like my pop would have built. of course i want a liitle more grunt so i am thinking of a 261 for her. i am between 2 and need some opinions A: '57 COLD COMPRESSION of (1-6)110#,95,115,95,105,110. this engine is very clean, freshly painted, generator,12v, at last run motor smoked "some" (no oil press reading as of yet, motor is inside a basement) or B:'60 operating temp (160 deg) compression (1-6)105#,110,115,110,110,85-90. no answer for low #6. motor is straight from a truck dirty, alternator,12v, oil press of 35 lbs @ low idle, 45-50 lbs @ high idle and "smoked very little"
what might i expect from the the compression when the 57 is heated up? is the compression critical between hot and cold as far as readinng the motor and being able to compare the two?
if it were your truck, what would you do? i am bowing to those of far greater knowledge and experience on this one. however, a '57 sounds like a 50's rod, a '60 just doesn't sound correct. inconsequential i know, but what the hey! thanks
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
I'd get the '60, overhaul it, and put 'er in. The '60 will have a better oiling system, as it is full flow, meaning all of the oil goes through the filter, instead of bypass like the '57 engine. As far as the year of the engine goes, unless you got someone breaking the codes, no one will know the diff.
Bill Burmeister
can you convert a bypass system to a full flow system?
Bigedpa,here are some links for the info you want.
A full pressure oiler
Click on tech tips,then full flow conversion
Hope this helps .
1951 3100 Chevrolet
The later 261 may have a large oil filter that hangs low on the RH side. If so that would probably cause some installation problems. Hard to say what you have available.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I had no problem using a 1960 large-truck 261 in my 1954 1/2 ton Chevrolet. The full-flow oil filter canister fit on the intake manifold, but I cannot recall if I put in on the RH (original) side or on the LH side, above the generator.
Tim
If the price is right, grab both of them. 261's will probably be in demand for some time to come, and once you get yours on the road, sell the leftovers.
can you tell the difference between a bypass oil syst, and a full flow oil syst by looking at the external filter and plumbing? here is a link to the 2 motors in question. i hope they work
http://pic80.picturetrail.com/VOL1958/10783339/19208600/307572728.jpg
http://pic80.picturetrail.com/VOL1958/10783339/19208600/307572724.jpg
the 57 is the bright green motor, 60 is the dirty blue
having read the articles on converting from a BPOS to a FFOS the plumbing looks large enough in volume to be FF on both. but i am just a rookie, thats why i am here.
It looks like the two filter canisters are the same. They also look like they are both full-flow oil filters. And, they both have the 1/2" NPT oil lines used on full-flow engines.
LIKE THE MAN SAYS, IF YOU HAVE TWO ENGINS AVAILABLE, BUY
THEM BOTH. THEY ARE GETTING HARD TO FIND. AND BY-THE-WAY,
WHEN YOU HAVE THEM APART, PUT THE ONE YOU DECIDE TO USE
TOGETHER USING AN OLD 235 FRONT MOUNT FRONT ENGINE PLATE,
THAT BOLTS TO THE FRONT OF THE BLOCK BEFORE YOU INSTALL
THE CAM SHAFT. THIS ENGINE PLATE WILL LET YOU INSTALL
FRONT MOTOR MOUNTS LIKE THE 235 HAD ORIGIONALLY, ALTHOUGH
YOU MIGHT HAVE TO DRILL THE HOLES IN IT AT PROPER
LOCATION. THERE WERE SOME 235'S THAT WERE BLANK. GO BOY.
The oil filter is easy to relocate to the front side of the intake manifold, just get some new hoses made.
Always make sure the valve clearances are to spec before you do a compression check, anyway.
Paint & Body Shop moderator
Now that I've seen the pics, both engines are the late 261 with the full flow filtration. I'll agre with the others, grab them both! Another option would be to locate the filter to the inner fender, which is what I did on mine.
http://rides.webshots.com/photo/2930928350092261295dryLgT
Bill Burmeister
