1 members (JW51), 186 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
Well I've owned it for a year now, a 58 biscayne auto 235. bought it for 2500, with 47k miles, it ran halfway good but needed help. tore it down this winter and gave it a head job, and purchased a offenhauser intake with 2 carter carbs, I just got everything back together and there is one problem, I can get it to start but it idles at like 3k, I cant seem to get these darn carter carbs to work right, any help, anyone?
Carburetion specialist
Get the numbers off the carburetors and give me a call during normal business hours. Will try to help.
Jon.
The Carburetor Shop
Had a friend come over that knows a bunch about rebuilding classics, he adjusted the carbs for me, But I need a more powerful fuel pump, where can I find one?
What is the flow rating and pressure of your present fuel pump? I assume it is the original mechanical unit.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
not sure it was stock till i replaced it last year with one from napa, the old one went out, but this one wont even blow your finger off the hose
Stock fuel pump shouldn't have any problem supplying dual carbs. Fuel line size should be min. 5/16". Check for kinks. Also check fuel filter and flow out of the tank, there should be a strainer there. If everything else passes, see if Napa will warranty the pump.
Fred
52 3600
69 C-10
:rolleyes:
Double action pump?
