| | | Forums66 Topics128,077 Posts1,056,033 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38450 03/16/2004 8:14 PM | Joined: Mar 2004 Posts: 37 New Guy | | New Guy Joined: Mar 2004 Posts: 37 | Well I've owned it for a year now, a 58 biscayne auto 235. bought it for 2500, with 47k miles, it ran halfway good but needed help. tore it down this winter and gave it a head job, and purchased a offenhauser intake with 2 carter carbs, I just got everything back together and there is one problem, I can get it to start but it idles at like 3k, I cant seem to get these darn carter carbs to work right, any help, anyone? | | |
#38451 03/16/2004 9:01 PM | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | Get the numbers off the carburetors and give me a call during normal business hours. Will try to help.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | |
#38452 03/16/2004 9:20 PM | Joined: Mar 2004 Posts: 37 New Guy | | New Guy Joined: Mar 2004 Posts: 37 | Had a friend come over that knows a bunch about rebuilding classics, he adjusted the carbs for me, But I need a more powerful fuel pump, where can I find one? | | |
#38453 03/16/2004 9:24 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | What is the flow rating and pressure of your present fuel pump? I assume it is the original mechanical unit. | | |
#38454 03/16/2004 9:30 PM | Joined: Mar 2004 Posts: 37 New Guy | | New Guy Joined: Mar 2004 Posts: 37 | not sure it was stock till i replaced it last year with one from napa, the old one went out, but this one wont even blow your finger off the hose | | |
#38455 03/16/2004 10:37 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Stock fuel pump shouldn't have any problem supplying dual carbs. Fuel line size should be min. 5/16". Check for kinks. Also check fuel filter and flow out of the tank, there should be a strainer there. If everything else passes, see if Napa will warranty the pump.
Fred 52 3600 69 C-10
#38456 03/17/2004 3:09 AM | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | :rolleyes: Double action pump?
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | |
