7 members (Ponchogl, wilbur53, Rusty Heaps, 49choptop, mason86, Peggy M, 1 invisible), 104 guests, and 0 robots.
Topics128,050
Posts1,055,680
#384120 03/06/2008 3:56 AM
Former Workshop Owner
Just curious, is there a website to enter a VIN from a GM vehicle to see how it was equipped when leaving the factory?
I am specifically interested in finding out rear axle info on several mid-eighties vehicles without having to actually jack them up and scrape for numbers, or pull off rear covers.
I realize that parts could have been changed, but it would sure help screen out the ones that I know would not work.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
J Lucas #384127 03/06/2008 4:11 AM
Not that I am aware of...
The newer VIN does tell motor size but I do not believe the information coded in the VIN extends to transmission, rear axle or any other equipment data beyond model identification.
There is a place where you can order a copy of the original option sticker for a Corvette based on the VIN. But I suspect that is based on records, not the code itself. Its possible that kind of information is available for other GM vehicles but if it cost $40 like it does on the 'vette it doesn't serve your purpose.
OldSub #384363 03/06/2008 7:39 PM
I have to agree with Old Sub, VIN doesn't cover rear ends..I've got a GM parts book that breaks down VINs up to 72...the book does list what rear ends were stock to model/yr, but that's as far as it goes..
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
