2 members (BC59, 1 invisible),
152
Mod | | | Forums66 Topics128,088 Posts1,056,110 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 217 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 217 | I have a 46 1/2 t and would like to replace the entire brake system. Does anyone know of a power brake setup with a duel master cylinder in kit form that is a direct fit for the 46?? I've talked to Jim Carter but they have the original single master cylinder.
Thanks, Rick......... | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | No direct bolt in. There are 2 types of pedal setups for the 39-46 trucks. One has the MC mounted to a bracket on the side of the bellhousing. The other, which was used on larger trucks has the MC mounted to the frame. IMHO it would be eazier to adapt the frame mounted style MC for a power booster. The system uses a clevis mounted off the brake pedal that ends up pulling a lever that is mounted to the frame. There would then be a push rod, and a Master cylinder mounted backwards with respect to the vehicle. the pulling on the lever actually creates a pushing on the MC. A frame mount bracket would be readily available for a booster and MC. Just need to drill a couple of holes.
John | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I was just wondering if anyone has tried a Tilton or Wilwood master cylinder? They both make a side bolt style that should easily mount to the 1st series trucks without using an expensive bracket. They are relatively cheap and have rebuild kits readily available. I figure if they can stop a 200 MPH stock car, why not an old truck? | | | | | Joined: May 2007 Posts: 275 Shop Shark | | Shop Shark Joined: May 2007 Posts: 275 |
No better smell than that of fresh paint. I've been building and painting cars/trucks for 47 years. Not gonna stop now. http://www.coxcustomcars.com/ | | | | | Joined: Mar 2005 Posts: 144 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 144 | I purchased an under the floor power brake system from Pirate Jacks and it bolts right to the left side frame of my 46 1/2 ton.The fronts are disk and the backs are drums so you might have to get a system specific for your application, (drum, drum or disk drum). There prices are very competitive and sell all the popular makes. I saved quite a few bucks as up here in Canada rod shops are far and few and charge you whatever they want. Hope this helps and good luck. Bob T
