4 members (78buckshot, klhansen, 2 invisible), 147 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#38418 10/25/2004 10:19 PM
Im going to have to replace the stock three on the tree in my 51 1/2 ton.Iwant to replace it with the same thing.What all years will be the same? Are all 3/4 tons floor shift?If i cant find a 3 on the tree will a floor shift from a 3/4 ton be a straight bolt up with out monkeying around with the drive shaft? Thanks,Ron.
1942 1\2 Ton
1951 1\2 Ton 55 willys cj-5
1954 and 59 Cushman Scooter
1960 Biscayne Sedan
1965 G/10 panel van
1966 C/30 Grizzly Motorhome
You know you're a 'Bolter when your daily driver is older than you are...
My progress pics
#38419 10/25/2004 10:40 PM
Riding in the Passing Lane
Late 47-54 will fit. I believe the 4 speed will
fit but the floor cover is different. It,s not
a good idea. It is heavy & awkward to r&r. 1st
gear is geared so low it,s not good for much.
3 speeds shouldent be hard to find or are not
to hard to rebuild. smile
1972 Chevy c10 Cheyenne Super
#38420 10/26/2004 10:14 AM
Thanks.Yhe reason i ask abought the 3/4 tranny is i have one on a chassis given to me.Mine doesnt want to stay in 3rd and being my daily driver what ever i do will have to get done in a day and soon. Ron.
1942 1\2 Ton
1960 Biscayne Sedan
1965 G/10 panel van
My progress pics
#38421 10/26/2004 11:16 AM
Quote
Check your side plate cover and your linkage. The side plates wear and the linkages get out of alignment. Replaced a transmission in the snow thirty years ago just to find out it was a worn side plate cover, learned the hard way. I was on my way from being discharged from the CG and I had no other choices.
