4 members (1955 1 Series, Wayne67vert, Brian Moore, Jon G), 45 guests, and 11 robots.
Topics128,012
Posts1,055,311
Members48,419
#383957 03/05/2008 10:22 PM
V
V Offline
Have a chance to buy an 86 firebird tilt steering set up. Builing a 49 chevy pickup cruizer. Wondering if this would work. Anyone tried this set up?
vickraft #384172 03/06/2008 5:56 AM
Y
Y Offline
Vickraft, what do you plan to hook the steering column to? MII, power steering, origninal steering gear? Just about any old steering column can be fabricated to fit in the truck. I put an S-10 tilt in my 53. You just need to figure out where the column will exit the cab, I moved mine over to line up with the Nova rear steer sub-frame. Only needed one joint. Theres lots of information on this site for fabricating the steering column, just do a search.
V
V Offline
Hi Yakimabowtie
I have mustang II kit from TCI. Will be installing sometime in May or June. I guess from what you explained, this column is a good candidate. Sounds like if I concentrate on clearance & alignment in as straight a line to the the mustang II power steering rack I should be ok.
Does the column have to be Tilt? The reason I asked is because I already have a real nice column from a 91 Astro that is not Tilt?
Thanks for your time &consideration.
vickraft #384491 03/07/2008 12:07 AM
I would not worry about the steering column now but wait until I had installed the MII then take measurements. You will find it difficult making the shaft a straight line to the MII. I have seen the shaft run through the firewall at about 2 inches below the original hole which allows the shaft to be almost straight to the MII steering box.
I am assuming you will replace the 216 with a SBC.
~Jim
V
V Offline
Thanks Big Chevy 3600 for the good advice. This makes good common sense. v6 will follow the Mustang II IFS.
