8 members (Hotrod Lincoln, sudsyz, Chip O, Gdads51, 1955 1 Series, stlcardinalsguy, tclederman, 1 invisible), 67 guests, and 0 robots.
Topics128,210
Posts1,057,456
Members48,471
I found four websites that claim to address the needs for antique truck radios, but they're all the same chinese garbage. For example check out this 54 GMC Radio. Anybody know where I can find a real 54 GMC truck radio - tubes and all?
Scout
1953 Chevrolet Truck Model 3600
1954 GMC Truck First Series Model 100
I don't know if I would call that "Chinese garbage" but offered new these days are modern radios that look fairly authentic when they are installed. This is definitely the case for the 47 to 53 truck radio.
Now if you want an original radio, they are not generally offered in quantity because they haven't been made for years. Probably what you need to do is contact one of the vendors that offers restoration services and see if they have one. There is one vendor that has radio hints, in the tech section. You could also look to buy one and have it restored.
1951 1 Ton Completed
Scout I know where there is one '54 GMC radio located in the Seattle metro. Contact me directly and I'll give you the details.
I talked with Hourhand the other day. He has a radio for a 54 Chevy. It should be the same. All you would have to do is get a new sticker for the display and BAM! you have a GMC radio.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
My understanding is that on the tube type radios polarity does not matter at all. I've not tested that, and haven't asked anyone who would really know...
Click here for pictures of a '54 - '55 1st GMC radio. These are NOT dial-up friendly pictures, but are high res shots I took when someone was interested in my GMC radio.
jdl Offline
I'm having no problem loading them.
Jordan D. Long
1954 Chevrolet 3100 1/2-Ton
And some more pictures
Photobucket
I got a 'Possum Pickup... Now I'm the Roadkill King!!! Anyone want to make some Stovebolt Stew?
Yes, the original tube only radios can be run with either polarity. The only hitch is when the vibrator is replaced with an electronic model. The elctronic replacements are polarity specific.
I was actually refering to a 54 Chevy Truck radio not a car radio in my first post. I also believe the 55 second series will fit the slot for your 54, but some modification may be needed.
"The Fake Truck"
Moderated by  truckernix
