Winter is Coming
A good Tech Tip WINTERIZING YOUR TRUCK including a link back to the Forums for additional tips.
Somewhere on the rear is a fill plug. If its the older rear it on the rear cover. Newer GM rear it will be on the pass side about 10:00 o 'clock maybe covered in dirt and grease. Dig around you'll find it. Its the seal that is leaking. If you're lucky its just because you haven't driven it enough to keep the seal expanded. Either way its a good time check it by pulling the plug sticking in your finger and see if you can touch the gear lube. If you can't go buy the correct gear lube for your year rear. 80w90 will work for most except the heaver duty trucks. If you have a clean rear I would recommend 80w90 Synthetic. Be good to your rear and drive it.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
Pu is right-on. You probably will have to put a pinion seal in it. If you have mechanical expertise you can do it yourself. Get a good book or post it & me or another bolter will give blow by blow directoins.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne Super In the Gallery Forum
It is the pinion seal that is leaking. I don't drive her in the winter she is stored in the garage. So I will dig around and find the plug and get that seal changed. I will attempt to research and do it myself. If I need help I know where to go that is for sure.
