Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
1 members (Shade Baby), 21 guests, and 4 robots.
Topics128,009
Posts1,055,293
Members48,419
#38366 04/09/2002 1:06 PM
Maybe someone can help ID the engine in my 58 3100.
I always read that these were gray. Mine is numbered F518A on the boss behind the distributor.
Has a road draft crankcase vent, canister oil filter on manifold
vacuum advance distributor and it's was painted light blue ( or blue green) no other colors under or over it
Seems to fit the profile of an engine of that era except the color. What do you think?
Life is to serious to be taken seriously
#38367 04/09/2002 10:34 PM
My "Chevy Truck ID Numbers" book says that it is a '58 to '60 car 235, 145hp 8.25:1 comp. manual trans.
The book doesn't cover car-type vehicles from '61-'63 but I would assume that it's the same to '62.
6 > 8
-Keepin' Things Inline-
#38368 04/10/2002 12:00 AM
Anonymous
Unregistered
Anonymous
Unregistered
OGRE9, if you can give us the # 's cast into the block just above the starter we can tell you what year , month & day your motor was cast. This # is probably buried under 50 years of crud. So get ta cleaning with a wire brush & some degreaser. This I.D. # will begin with CON......
#38369 04/10/2002 1:17 PM
I'll get the CON # It's already nice and clean ready to come out for a rebuild Thanks. BJ I seem to recall an engine called a blueflame six would this be one?
#38370 04/11/2002 5:39 PM
And the nuber is------------ CON 3 F169
#38371 04/12/2002 4:27 AM
Anonymous
Unregistered
Anonymous
Unregistered
M.T has decoded the # & the results are as follows........ June 16th 1959.
Keep the old iron goin'
#38372 04/12/2002 6:46 AM
Advanced Designs, maybe you can help me out, I have a engine that is a 308 gas engine stright six, and every part store I call or send email to don't belive there is no such thing is a 308. The only number I come up with is 3088618, the engine goes in three pieces and the model number is AFR 522, this is not a Milatry Rig it's a "cilvilan"
also the bearings are insert type.
Times are changing-By Bob Dylan
Cindy in Oregon
1945 GMC COE Victory Truck 5ton COE- NOT FOR SALE
1955 Chevy First series 5 window p/u
1947 Antique Husband only series
#38373 04/12/2002 1:23 PM
Thanks all
George
#38374 04/12/2002 9:18 PM
Cindy, the 308 GMC as well as the smaller 278 were heavy truck engines 1941-1948. Big, heavy, lazy motors used in road tractors and other commercial vehicles. They are descendants of the Buick inlines originally used in GMCs. Check with Tom Langdon at Stovebolt Engine Co. www.stoveboltengineco.com, I believe he has some parts sources for these engines.
#38375 04/15/2002 8:52 PM
Chances are, if the engine doesn't have an oil filter on the bottom, it is a 265. (yucky, nasty, dirty engine) casing number is above the bell housing-on the block- drivers side. Large and easy to read- have to get the grease off first.
