7 members (TexasJim50, DadsFirstPickup, 54farmtruck, Patharr, klhansen, Pete1946, 1955 1 Series),
114
Mod | | | Forums66 Topics128,148 Posts1,056,811 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 6 New Guy | | New Guy Joined: Nov 2007 Posts: 6 | I am looking at replacing my entire brake system and I would like some suggestions. Here is what I have now.
1951 Chevy 1/2 ton Front is original. Rear is a 12 bolt from early Camaro. Master Cylinder is original. 3 speed on the floor.
I have been looking at an ECI kit for the rear, and Classic Parts 5 lug disc kit for the front, that includes the MC.
I have read that the Master Cylinder will have clearance issues with the 3 speed, what can be done to fix that?
What other kits would you recomend? Also, if I am missing something can you guys help point me in the right direction?
Is it realistic to think I can have this completed by April 12th? I am planning on driving this home from my wedding. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If you don't already have the parts in hand, it's doubtful you can have done it by April 12. It takes a while to ship and some vendors have it shipped from the supplier.
I think most of the vendors sell the CPP kit. I used it in my '54 GMC and had to modify the M/C bracket. Don't know about the 3 speed problem as mine has an automatic.
Stock 15" wheels can't be used with the 6 lug brakes. Don't know about the 5 lug set-up.
Click on my trucks website link for more on the problems I had. Click "54 GMC" then "front suspension". | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | i have a 12 bolt rear that's 6 lug. my front is disc and you can not run stock rims w/ disc. my master is a power master cylinder and i had no problems w/ the bracket after removing the old. i got it all during a Brothers sale. it's probably cpc's ?? not sure. i used 3/16'' lines purchased from any FLAPS w/ double flared ends and a couple of unions & T's. the tubing is easy to bend by hand. i also bought 16'' x 1/4'' dia, stretched to about 30'' long surplus springs to make a Brake line covering. I used a simple rubber electrical wire chassis holder to hold the lines on to the truck frame. http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=2748800-R1-045-21.jpg http://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=DSC00493_0007.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=579990-R1-012-4A.jpghttp://s67.photobucket.com/albums/h298/1951otter/?action=view¤t=579990-R1-016-6A.jpgthe master came w/ a proportioning valve so I have no problems there. I did not pre bench bleed my master, I did it all after I had installed it on the truck w/o issues. just make sure you use flaring wrenches and everything is dead tight. a coke bottle and a clear line to bleed. To make it all work and fit right I measued - fit and then took the lines to a brake shop and for about $15.00 they double flared all the ends I cut to length. I then installed the system in a couple hours and made my final adjustments then finished assy. A custom fit job.
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | I'm just throwing something out here to see if anyone has a take on my idea. I have a 3600 with 8 lugs. I would like to upgrade to discs but I ran into a snag. Nobody makes parts for it! It looks like to me that a late model disc (99 and up)should slip right over the hub and it is just a matter of fabricating some brackets for the caliper. The only problem I forsee is with the roller bearings. I don't know how well they will hold up and the only company that makes them is Federal Mogul. There isn't any Timken upgrades like the 1/2 tons have, so OEM is it. There is a rear disc kit out there from Street Rod Manufacturing, but who wants rear discs and front drums?
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Do a search, several folks have started on making a kit, or at least providing drawings and part numbers, I have not heard an update lately.
Personally, I would start with the straight front axle form a "step van" with 8 lugs and disc brakes, narrow it and be done.
Grigg | | | | | Joined: Feb 2000 Posts: 769 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 769 | FYI,
The last time I checked, Brothers does not sell the CPP brake kit. It is a different kit. Brother's caliper bracket is welded and CPP's kit is bent. This pertains to the 6 lug kit, but I would think they would get their kits from the same vendor. | | |
