4 members (baldeagle, Otto Skorzeny, tclederman, Rusty Heaps), 58 guests, and 9 robots.
Topics128,020
Posts1,055,345
Members48,419
#383496 03/04/2008 10:56 PM
I swaped my 53 16in. wheels for some 15in. wheels that have 3 bumps where the hub caps pop on.I ordered a set of baby moons for 15 in wheels ,10 1/8 in. inside, that was supposed to fit but were to small. Can someone tell me the yrs. of trucks these came out on,or even better where to get some babymoons to fit the truck. THANKS
Popa Kents Body Shop
popa #383696 03/05/2008 4:57 AM
The 6 lug 15's with the hubcap bumps are 60 through 72 to the best of my knowledge.
Fred
rfs56trk #383704 03/05/2008 5:09 AM
the 3 bumps started 61, the 60 has the clips and same caps as 57-59
popa #383722 03/05/2008 5:43 AM
Thanks guys. Any idea where to get babymoons ? I was going to get the plain ones and have the chevy script made to make them look like the 53 caps that belong on the truck.
popa #383860 03/05/2008 6:04 PM
Parts stores like O'Reilly's have Mr. Gasket moons. Also, they have lots of them on Ebay.
'64 swb stepside (gone)
'57 1 ton
'53 phone truck
'59 swb
'46 1 1/2 ton
'68 swb gmc
jfnar #383871 03/05/2008 6:25 PM
I had the same situation on my 53 and I could not find baby moon caps to fit. There must be some out there.
When you find them you can put bowtie decals on them. Available at all aftermarket suppliers.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
popa #384760 03/07/2008 3:12 PM
I tried Mr. Gasket they have standard 10 1/2 caps that are 2 small. Come on now. Some one knows where to get these. Give it up.
popa #384782 03/07/2008 3:58 PM
see and try to fit like:::
http://www.speedprint.com/deves50/deveshowto.php
deve has a way to mount old hubcaps to newer wheels
Deve's Restoration Rant
History of Advance Design Trucks
Deve's Frame-Up Restorations
Advance Design
Parts Resources
Deve's How-To Resources
Restoration Support Links
NEW! Your Trucks!
Smokey's Hubcap Clip Installation
Now viewing items 1-8 of 8
Step 1: The first thing you have to do is determine where the clips are to be mounted on the wheel. You can hold a couple in place with tape to get an idea of where to mount them, then you can lower the hubcap over them to see if it will be a snug fit once they're installed.
Step 2: I found that it was necessary to flatten the clips out somewhat. Laying them down on a flat surface and striking them with a hammer will do this, but be careful. They can break, so it is a good idea to have a few extras just in case.
Step 3: Once you decide where you want the clips, you can mark with a pencil. I will not paint the rim until this job is done, so that I can see my marks as I go.
Step 4: Now you can take a punch and mark your holes to be drilled. I recommend installing 2 clips at first; one on each side, just to see how the hubcap is going to fit. I chose to install a total of 4 per wheel, which works very well.
Step 5: When you drill the holes, obviously you want a hole smaller than the screw that you are going to use. The reason I mention this is that if you twist the screw too tight, you can break it off, which can really be a pain!
Step 6: Referring again to breaking the screws off, I highly recommend a nut driver or screwdriver, as opposed to a ratcher or drill. I guess you can tell, I broke a couple off before I finally got smart!
Step 7: The hubcap should fit pretty tightly once the clips are installed. Be careful to see that each clip goes to the inside, and not the outside of the hubcap when you snap it on.
Step 8: Here's the good part. The clips can be adjusted, once installed, by tapping with a hammer and/or tightening or loosening the screws as necessary until you get a tight fit. Be careful with the hammer, because the clips, as stated earlier, can break, so it's a good idea to have a few extras on hand.
With a coat of paint and the addition of a chrome beauty ring, the hubcap looks pretty good, wouldn't you say? And I might add that if I can do it, anybody can install these clips! Good luck!!!
Jim & Caroline
carolines truck #384791 03/07/2008 4:16 PM
Jim - try fixing the link in your post and it'll be up - need to have a space at the end of it >>>> http://www.speedprint.com/deves50/deveshowto.php SPACE
Flxible #386032 03/10/2008 12:30 AM
thanks bill
Jim & Caroline
