3 members (klhansen, ronsway, 1 invisible), 165 guests, and 1 robot.
Topics128,106
Posts1,056,213
Members48,436
#378620 02/22/2008 8:14 AM
Hello to all the members out there,
Does anyone know if the '53 Hood latch panel fits a '54. Looks like the bolt holes are the same. I bought a forward tilt kit from No Limit Engineering years ago and have never finished the install. They hadn't mounted it to a '54 so wasn't sure if it would fit after I had bought it. The '47-53 has more of a recessed area than the '54 and I need that so it mounts correctly. I think the hood is the same for all years '47-55 1st. The truck will be in the bodyshop getting a new grill and would like to replace this piece if all matches well. Might have to update my hood also. Thanks, Dave
1954 custom 1-ton (1 of a kind)
Dave,
My guess is that the plate-panel is different but the catch-assembly on the plate is the same?
If the plate is 8.080 in the Master Parts Catalog, 54/55 is different from earlier Advance-Design years.
It looks like the catch-assembly is part number 8.028, and that part is the same for all years.
Tim
Houston54
Unregistered
Houston54
Unregistered
I did a little experiment on my 54 where I used a earlier radiator shroud panel and tried to bolt a 54 latch mechanism to it. It fit fine. From what I can tell the only difference between the panels is the 54-55.1 has some wiring loom hooks riveted to the back side the earlier panels do not. They will interchange.
As for the hood latch itself the only difference between the 54-55.1 and the earlier latches is the release arm on the 54-55.1 is different to accomodate the new style grill. The old latch will function just fine though with no interferences.
#378796 02/22/2008 8:20 PM
Thanks for the info. Ya I rearended a car the other day and need to replace the grill now. New chrome for $700 from Classic Parts is on its way. Can't beat the $250 Deductible for my insurance, meant to replace that any way. Now need to order that panel, which comes with brand new latch installed, so I can mount the hood correctly. Owner of bodyshop wants to replace my hood if insurance will let him. I paid to get all the body work done last year when my truck was in the shop from a hit & run and I didn't have collision then. The hood has a lot of bondo on it. It might be worth it to drop a new one on. Never had the front emblem or the 3800 sides for it. Do you know of anyone that might have these. Wouldn't mind putting them on if I replace the hood.
you might find them on a site like fillingstation or classic parts
to much to do to little time to do it all
McAllen, TX
1948 Chevy Loadmaster flatbed fire truck
http://rides.webshots.com/album/562569229snLyQV?vhost=rides
Or.....E-bay usually has those pieces.
Houston54
Unregistered
Houston54
Unregistered
I noticed recently that the AD hood is now being reproduced. Cannot recall which outfit had them but check around and I am sure any of them can get it.
#379823 02/25/2008 8:51 AM
Believe it or not, the hood is listed by many. But can't find a single one, I called already.
Dave
TC,
Just checked with them. Still haven't received their shipment. One batch came in but the two halves didn't match-up correctly.
Fairline company that does all the fiberglass for Fords has a complete glass front end that tilts open for $1600. Address is http://fairlinecompanymi.com Dave
