6 members (mk72, SNOYL, cmayna, JW51, 78buckshot, Phak1), 56 guests, and 6 robots.
Topics128,012
Posts1,055,320
Members48,419
#382865 03/03/2008 4:53 PM
Sorry to ask this guys I know it's on this site somewhere I just cant find it? Trying to identify my 235, cylinder head casting number is 3835913 I canot find a block casting number anywhere???? number stamped on pad is O25950I F54X and finally behind the starter is A-274 anyone know what I have???? Thanks in advance.
1965 chevy c-80 409 5-2 20000 original miles.
1965 chevy c-60 348 5-2 single axle tractor.
1952 chevy p/u 235 4 speed restored.
1965 chevy c-60 couch.
One grouchy wife. FOR SALE....CHEAP!!!!
The future is not what it used to be.....
Have a new pair of metric vise-grips and large metric hammer, can fix anything...
Here is some information
235 Engine ID Info
I have a 53 passenger car motor. It has the same head casting number (3835913). On the other side of the head from the casting number I have a cast in B36 then 913, 241, and 570 stacked on top of each other. I think that the B36 means the head was cast on the second month (B) the 3rd day in 1956? B36. This would mean my motor was rebuilt with a different head.
I would be interested to see what numbers are cast into yours. See this link. Head date???
I think from the first link above, yours was the 258501st block at that plant that year. They started with #1001. F means the Flint plant, 54 is the model year and X is the engine type. The table linked above has types for the 53 and older trucks. It looks like it only has data for 1954 cars. I guess that X is for a truck motor.
Here is where my block casting number is. The front lower passenger side just above the oil pan.
Block casting number
Here is another picture of the new motor I am installing. It is a 57 motor. This is behind the starter and is the date code.
Date code
In this case it was a November 21st, 1956 casting, which would have been put in a 1957 model truck.
You said yours had A 27 4. I would read this as January 27th, 1954 as your casting date.
I am not sure where I read it, but there are 2 screw heads. I believe these held the date plate on the form. In any event, somewhere I read that you can tell if it was cast 1st, 2nd, or third shift. For example, the first shift might have used 2 flat head screws, the second shift then use a flat and a round head with the third shift using two round heads. I am not sure which was which though.
Also, you can see on this 57 block that the beginning of the casting number is just forward of the distributor above the GM.
Hope this helps.
Also check out www.inliners.org. They have some info about casting numbers as well.
Todd M #383402 03/04/2008 6:42 PM
Thnaks todd, that was the info i was looking for.
I think that 3835913 is a head code from 1954 and 1955.
A 1953 Powerglide passenger car head would have the same head-bolt arrangement as the later heads/blocks; but, it would not (I think) have a 4-bolt valve cover (it would have a 2-bolt valve cover as used in low-pressure 216/235 engines).
tclederman #383494 03/04/2008 10:56 PM
The engine that was previously in my truck was from a 53 car with Powerglide and it had a 4-bolt valve cover on it. A friend and I pulled the engine from the donor car back in the 70's and he knew it was the original engine in the car. (there were only a few minor differences between the 53 Powerglide engine and my truck's original 1954 235)
Samantha
1954 Chevy 3100
Picked from the Field
Follow in the DITY
Samantha #383725 03/05/2008 5:51 AM
My 53 motor is the first hydraulic lifter motor. What I don't know is if this is the head that came with it. It has the newer 4 bolt valve cover. Can anybody tell me if head have thier own date code? I am just guessing that the B36 on mine means Feb 3 1956, but that could be entirely wrong.
