3 members (TUTS 59, Guitplayer, Otto Skorzeny), 34 guests, and 3 robots.
Topics128,036
Posts1,055,448
Members48,422
#381038 02/28/2008 2:49 AM
Hi All,
Plan is to use electrolysis to remove rust from my bumper brackets, but I thought first I might soak them in drano to loosen the paint and any undercoating. Will that help? How much drano to 5 or 10 gallons of water? I know to wear gloves and goggles around that stuff. Last part I did electrolysis on still has some paint and undercoating on despite going for 1 or 2 days & I brush off the re-bar every 8 to 12 hours. So I'm hoping to speed things up a bit with a pre-soak.
Is it Ok to add drano right into the electrolysis bath with washing soda also? That might stop me from sticking my whole arm in to clean 30" long pieces of re-bar, but would work on the smaller stuff cool
Eric
http://s1199.photobucket.com/user/sparky234/library/My%2057%20Chevy%20Stepside?sort=3&page=1
'57 Chevy 3100 (Little Red)
'81 RD350 LC - Fun, Fun, Fun
'83 GS1100E - Pocket Rocket
electrolysis will have no effect on sound paint, it's a corrosion removal technique only .... real bad idea to mix home brews of chemicals - Drano is 3 sodium chemicals [along with aluminum], that creates heat in combination with water, as well as hydrogen gas, NOT what you want at the business end of the battery charger, or for stripping paint - try some paint stripper, and rinse it off well before the electrolytic bath
I thought Drano no longer contained lye?
~Jim
I used Drano to strip a license plate and it worked well however as Bill stated it creates heat, gas and smells. I wouldn't think of using with a battery charger. There are much better avenues to use nowdays. Only advantage to using Drano is the disposal after using. Just flush!!
Dan
I bought some liquid drain cleaner that contained sodium hydroxide and potassium hydroxide. I put 2 cups of that with 3 gallons of water and 2 bumper brackets. Here are some before/after pictures following a 2 or 3 hour soak. Worked pretty well.
http://good-times.webshots.com/photo/2492723160101537469khMMoL
http://good-times.webshots.com/photo/2681489900101537469zKrhcw
It seems Red Devil has quit making lye. I found some sources on the web, but I'll call some places around here and see what I can find. Box stores didn't have any.
Eric
Well I taint done my composition for this morning so I guess this is a good enough place to get it done.
I have to agree with the other guys on the paint striper. I pick up Mar-Hyde Tal-Strip II, Aircraft Coating Remover at F&F and it’s relatively inexpensive. Spray it on, wipe it off in 5 or 10 min. no problems disposing of it either. Next morning the pile of paint is just a lump of dried up paint.
Lye was about the only option years ago but with the new chemicals available today I don’t see any reason to use a caustic product like lye.
Oh and if it makes any difference, I strip, scrub with detergent, remove rust by method of choice, scrub with detergent then finish.
Looking at your bumper brackets Eric, they are in great shape, I simply would have taken them to the pedestal grinder with a wire wheel, scrubbed them with detergent and finished.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Drano IS lye [sodium hydroxide], with some other things added, and considering the hazards of it, there's just no reason to use it for a job easily done by friendlier methods ... in addition, sodium hydroxide is highly corrosive and isn't corrosion our biggest problem with this old tin? eek
