7 members (Jeff Ogden, baldeagle, Wheelie, joe apple, 51sub, Ponchogl, cmayna), 63 guests, and 5 robots.
Topics128,021
Posts1,055,346
Members48,420
#382454 03/02/2008 5:55 PM
I getting ready to put a TCI 4 link and a S10 rearend in my 37 1/2 ton. They only sell the 4 link for the car which the frames are different and the front mounts need to be modified. Has anyone tried this? Any info would greatly help.
37truckman #382518 03/02/2008 9:15 PM
U
U Offline
Try to keep the bars as level as possible.
If you can triangulate them you will not need a track bar.
I guess the easiest way would be from the C type trucks.
They ran two long bars and a track bar. They ride and handle real nice. But where prone to axle hop if you got them in a bind in reverse.
underdog #382529 03/02/2008 9:40 PM
I'll look into how they had the C type trucks. I guess my biggest concern is the 37 truck has a C channel frame and the 37 car has a I beam frame. Just different enough to couse me a large pain. Thanks for the info underdog.
37truckman #382550 03/02/2008 10:34 PM
U
U Offline
http://www.carbibles.com/suspension_bible.html
Chevy C types used "they term" Solid axle - coil spring type.
They also show a 4 bar triangulated, on the right in 4 bar section.
There is lots here for you to think about.
underdog #382614 03/03/2008 1:53 AM
~Jim
BIG CHEVY 3600 #383046 03/04/2008 12:17 AM
Thanks for the great info guys. It will be very helpful!
