| | | Forums66 Topics128,269 Posts1,058,402 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2003 Posts: 181 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 181 | Hi gang! Well, I have finally given up on ever finding a carb (other than Rochesters) for my 261 so am now at the point of thinking about picking up a complete engine (with carb) and dropping it in. Will a 292 or 283 match up to my bell housing and motor mounts? (It's a 1962 C-30) Or do I have to go with a 216 or 235? Thanks, David
The only thing more amazing than my ability to cram 60 minutes of work into a 9 hour day is my talent for making it look effortless! My 1962 Chevy C-30 | | | | | Joined: May 2007 Posts: 95 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 95 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | If you haven't given up on your 261, have you looked at the manifolds and the carbs available at The Stovebolt Engine company? Dual Holley-Weber & Carter-Weber carbs seem to work fine for many people. I'm putting up with dual Rochesters but may switch to Carter-Webers. | | | | | Joined: Feb 2007 Posts: 385 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 385 | I agree with tclederman. I think a Holley-Weber or Carter-Weber will save you a lot of work money and trouble. I've looked at replacing my 235 with a 292, and the offset motor mount scares me a little. A V-8 is going to make things pretty tight under the hood, and the tweaks won't be free. Motor mounts for a V-8 are going to run at least $50 and I've heard that someone has a complete ??-Weber kit for less than $100, with linkage and manifold water heater.
195? Chevy 3800 dump truck 1973 Chevy C30 cab and chassis 1987 Suburban 3/4 ton 6.2L Diesel
| | | | | Joined: Jan 2008 Posts: 360 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 360 | was considering the same set up in my 46 1/2t. just saw on the stovebolt engine company site the bolt in engine mount kit for $120. that should make things a little easier. http://www.stoveboltengineco.com/acartpro/product.asp?productid=138however, there seems a need for quite a bit of consideration when going to the 292 for bellhousing, clutch, tranny and so on. see my thread in here 261 vs 292 lots of things to think about
"it's only old if you can't find a use for it; otherwise it's cool and i'll use it."
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | I went with the Holley/Weber setup on my 56-235 engine....couldn't ask for a more trouble-free fantastic performing carb. Eliminated all the inherent issues commonly found in a Rochester. Have pictures of the install and linkage setup in my Webshots album.
After initially suffering from all the leaking, fumes,hard starts, poor idle, hesitation and rich conditions from a heavily worn Rochester, the Holley/Weber was the most logical fix. Ditto for the Carter/Webers that I'm running on my 60-235.
Stovebolt Engineering has put together a great combination that will appeal to any driver who wants the most bang for their buck.
Dave | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | Holley/Webber 2 bbl carbs from Langdon's Stovebolt are cheap and work very well. They even cell an adapter to bolt onto the original manifold.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
