9 members (Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 52Carl, dt235sd, BC59, 2 invisible), 153 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#381847 03/01/2008 1:46 AM
I have been working on my 51 sub for about 7 years now. But you know I think if I had good replacement parts it would be done now. It looks like to me All PARTS are just as bad or worse then the old ones. And then you have to return the things only after someone on the other end tells you are nuts. will send some pix just as soon as I can get my grandson to help. GETTING CLOSE Jack
No,Jack. Youre not the only one. Weve all been there probably too many times than we care to mention.
Hang in there,,it'll all fall together someday soon.
Good Luck,
jm1327: stay with it because it gives the rest of us hope. I've been on my panel for 2 years now and still counting....for a loooong time I'm afraid. We all love to see pictures so bring them on.
#382017 03/01/2008 2:57 PM
Leo Offline
Moderator
Moderator
Don't succumb to the seven year itch, Jack. Bit by bit it will come together. Mabye your grandson will help you with it.
Leo #382097 03/01/2008 5:33 PM
Dont lose hope. Just think about how much fun you will have cruising when its all done! We're pulling for you! wave
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
Jim1327, hang in there. I bought my 49 sub in 2002 and have been working on it for 6 years. The only reason I work a part time job is to finance the truck. I too have "hit the wall" in this endeavor but managed to work through it. The closer I get to being finished the more I feel like working on it and it's almost done. Like I said hang in there. It WILL happen. Weeds
Weeds #382440 03/02/2008 5:20 PM
Seems to me we all have "walls" at different times. I have had my 49 for about ten years and have encountered about three- four "walls' that caused me to pause for a year or so. Once I renegaged the wall that I didn't know how to accomplish weren't that tough.Like toomany 2 count I have had "bourbon" running and have driven on 4-5 occasions which is a huge emotional lift even if it is just around the block. With any luck 2008 will find an inspection tag and license plate on the old gal. Keep plugging and you will make it.
Opportunity is missed by most people because it is dressed in overalls and looks like work. - Thomas Edison
Things may come to those who wait...but only the things left by those who hustle."-Abraham Lincoln
I
I Offline
jm1327, I don't think it is at all unusual for someone to hit a wall. I spent years deciding what to build. Years ago I saw a dark green Sub and wanted it in the worst way. It came up for sale and was gone as was my dream. I found one about 4 years ago and its been in my mind ever since. It has a great grille! But is going to need a lot of work every where else. Hang in there you'll eventually get er done! Weeds, I have a couple of questions for you, Where did you get the rear cab corners? Both of mine are shot and need to be replaced. Is there anywhere to get rear fenders? I assume an AD pickup is different. You have pictures of your body lifted in the air, any idea what the body weighs? What size ceiling joists are you lifting on, or do you have extra support?
inuke
'49 Sub
'49 Fleetline
1952 GMC Suburban
1949 Chevy Suburban
1949 Chevy Fleetline
Stories in the Gallery
More pix on Photobucket
