1 members (53 green 1- ton),
110
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,072 Posts1,055,907 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 19 Apprentice | | Apprentice Joined: Dec 2007 Posts: 19 | Does any one know how many colors are available for powder coating? If so, is there a chart?
Keep the Taskforce Trucks Alive....
Tim Sorby fellow bolter
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I would check with the company you are considering. powdercoat for the most part can be done in virtually any color you can get in paint. I've even seen some specialty finishes that they do with a single component poder that would take 2-3 different paint coats to achaive the same effect.
Bill Burmeister | | | | | Joined: Nov 2007 Posts: 131 Certified Bolt Nut | | Certified Bolt Nut Joined: Nov 2007 Posts: 131 | Yeah the shop I just picked up my stuff had a chart of all their colors, probably 250 or so. Their price was different depending on the chosen color (some were "special" mixtures) but just about every color you could dream was covered. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Ditto the above. When I got my wheels powder coated they had a whole wall full of 3x5 samples of their choices. I used Prizm in Ponca City.
