| | | Forums66 Topics128,068 Posts1,055,883 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | Got a replacement water pump from NAPA for my 235. The old pump has 2 holes, one for the heater hose and one with a plug. The new pump just has one hole. Will it work to take the adapter for the heater hose off the old pump and put it on that single hole on the new one?
For reference, the old pump looks just like the one that classic parts and LMC sell.
edit: What is the second hole for?
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I don't see why not. The pump on mine only has one hole.
Bill Burmeister | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | The second hole is for a 261 with a bypass thermostat, but other than that its the same as for the 235. The adapter should be 1/2" NPT threaded.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Dec 2007 Posts: 58 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 58 | Very good. Thanks. Was worried there for a bit thinking I had the wrong pump. Hope to finish the project tonight. | | |
