7 members (Phak1, JoergK., Goach2, dt235sd, Alex52, J Lucas, 1 invisible), 78 guests, and 7 robots.
Topics128,188
Posts1,057,216
Members48,465
#380845 02/27/2008 6:29 PM
I currently have 8 lug 4.10 posi in my 66. I now have the chance to purchase a 6 lug 3.54 posi.
Will this swap give me a significant speed increase? And can I change out the gears to increase the speed even more.
I currently have an NP435 trans (reverse on passenger side)
You can calculate the improvement here:
http://www.onlineconversion.com/bigger_tires.htm
To find out if you can get faster gears for any rear axle you first need to know what make and model axle it is, and in some cases what year. Then go to any gear shop, like Randy's Ring & Pinion or a bunch of others, and see what they offer for that model axle.
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Thnks Gigg nice site
I dont know my trans ratio, its an NP435
here is another one i use you dont need all the tranny ratios just the last gear ratio
http://www.angelfire.com/fl/procrastination/rear.html
That ratio change represents a 4% change which is very small.
1951 1 Ton Completed
Sure it is not a 13.6% change between 4.10 and 3.54?
At 65 mph the engine speed drops about 450 rpm, that sounds like a worthwhile swap to me.
Grigg
---All pictures---
Not bad on the numbers, but he would have to derate the truck. The 1/2 ton and 3/4 ton gears don't interchange to my knowledge, so he would have to swap the entire axle. I think a transmission swap would do a little better in the 3/4 ton truck. A 27% overdrive will make an effective drive ratio of 3.00. That isn't to shabby! Use a transmission like the NV4500 and you wn't lose too much in the low range either.
Billybolt,
I have a 3/4 ton GMC rear at 4:57 and want to swith the pumkin with a newer GM 3/4 4:10. Is the old 66 8-bolt rear pumkin available?
Also considering to use a T-5 tranny with .72 O.D. to go 65 mph at 2764 rpm (with current 4:57 rear).
Eric
