2 members (Hush, Forty9),
90
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,643 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#38060 07/26/2004 9:47 PM | Joined: Jul 2000 Posts: 621 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 621 | Saturday I got to work in the garage for a while and now have my Offenhauser 3X intake and my 3 Carter/Weber progressive 2 barrels installed. I did end up having to cut my firewall to make the back carb clear but it's not too bad and I'm gonna fab a box up to go in that space when I do my firewall cleanup here soon. I still need to do some tweaking on the linkage and the fuel lines (Not installed in these pics) But I got to fire it last night about 10 and it sounds great. It wouldn't idle so I need to make some adjustments but I think it's gonna be pretty mean when I get it all wrapped up. [img] http://www.chevygmcofkc.org/Gallery/data/3021/1100_1870s.jpg[/img] [img] http://www.chevygmcofkc.org/Gallery/data/3021/1100_1871s.jpg[/img] O' and for the guys who don't know me this is in my 53' Chevy pickup with a 235/T5 combo and an open rear end. Mongo | | |
#38061 07/26/2004 9:58 PM | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Great Pictures KC , what are those huge carbs? It looks a similar setup to that which was on my McGurk tricarb but it had the old Rochester B carbs on . (and no hole in the bulkhead  ) Have fun  | | |
#38062 07/26/2004 10:04 PM | Joined: Jan 2001 Posts: 1,422 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,422 | Looking good KC! Those are good looking carbs, what are you using for air cleaners? 3 singles or are you going to make a single log? What do you use for mufflers on your dual set-up? Nice truck. Cosmo
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#38063 07/26/2004 10:05 PM | Joined: Jul 2000 Posts: 621 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 621 | Dusty, They're a Carter/Weber Progressive 2 Barrel from Langdons Stovebolt. Yeah I tried to avoid the hole in the firewall by removing the electric choke from the rear carb and reworking the linkage so it was smaller but it just wouldn't clear. Here's before and afters of that carb. [img] http://www.chevygmcofkc.org/Gallery/data/3021/1P6240053-med.JPG[/img] [img] http://www.chevygmcofkc.org/Gallery/data/3021/1P6240064-med.JPG[/img]] Several of my buddies (and I'm sure some guys on here too) will give me trouble about cuting the firewall but I was very carefull to cut it out so that it could be welded back in easily if I ever decide to go back all stock (not likely at this point). Cosmo, Not sure on the aircleaner yet, prob will end up being some kinda log, although I'd love to modify 3 old oil baths to put on it but the back one would have to be flat on one side. My exhaust manifold is an early Kansas customs stock manifold split and I'm running Flowmaster 40's for mufflers. MONGO | | |
#38064 07/27/2004 4:16 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Looking good, Mongo. There's just no getting around cutting the firewall for triple carbs unless they're sidedrafts. Looks like you have manifold heat, I think. Also, on the choke, on my friends truck with duals he only has one choke connected. It's a little cold-blooded, but not bad.
Fred 52 3600 69 C-10
#38065 07/27/2004 8:08 PM | Joined: Jul 2000 Posts: 621 "MONGO" | | "MONGO" Joined: Jul 2000 Posts: 621 | Ok, so last night my buddy Rick came over to help me do the final tweaks so we could get the truck out for a testdrive with the new carbs. Turns out it wouldn't idle because of 2 vacumn leaks I hadn't notice the night before (it was dark and I was sleepy) we plugged those up and it idled out nice but a little fast. Turned all the idles back 1/4 turn and adjusted the linkage on one carb that was not bottomed out and hit the road. With the 3X it's like a night and day difference!! More power, rev's faster and cooks right on down the road. I got rolling scratch on accident pulling out at one point! Over all it's a huge change I'd recommend to anybody running an inline. Today I ordered the HEI from the Stovebolt company, it should be in friday or so more info (if anyone cares) once I get it installed.
MONGO | | |
#38066 07/30/2004 7:25 PM | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | looks great! stock firewall? who cares, you've got 3 carbs! any other mods to the motor or stock? | | |
