1 members (Danielbolt), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
I am having trouble finding front brake hoses for my 1970 C50. No parts stores seem to have a listing for it??? If any one knows where to get them, or can get me a part# for them it would be greatly appreciated Thanks
1970 C50 dump! saving orphans from the CRUSHER
3B Offline
Hy rust master, I found two listings, depending on whether it has a 5000lb. or 7000lb. front axle
5000lb. axle = BH36697 - o.a.l. 24 13/16", this one has the hex for tightening the connection to the wheel cylinder back from the end
7000lb. axle = BH36696 - o.a.l. 26 3/8", those are Raybestos numbers, hope that helps.
Riding in the Passing Lane
My Napa catalog shows the same numbers as 3B,s minus the prefix letters.
1972 Chevy c10 Cheyenne Super
Rockauto.com has those parts for $39 and $43 (Do a "Part Number Search" - top menu). Their shipping costs are low, parts arrive in 3-4 days, and no sales tax, unless you live in Wisconsin.
I just have to figure out what axel I have. How can I do that? is it just the GVW of the front on the tag? mine does have the hex on the end of the hose where it screws into the wheel cylinder ( wheel cylinder end of the hose is threaded )
On my 67 C50, I used all standard earls plumbing fittings and lines, and adapted it over where needed.
On the front, I used a banjo bolt, with banjo, and a 90 degree angle brake line as a replacement for the special threaded ends.
