0 members (), 91 guests, and 2 robots.
Topics128,050
Posts1,055,643
Has anyone seen a source for the cast spring perches that are riveted to the frame? My rear frame mounted spring perches are worn so much that new bushings wouldn't last a mile.
I could fab new ones from plate steel, but I'd rather replace with original style.
49 Chevy.
1949 "Heinz 57"
Used is about the only route you're going to be able to get them. I'd suggest checking in the Parts for Sale, or hit the local salvage yards.
Bill Burmeister
I have a set for $25.00 plus $10.00 shipping you can contact me at [email protected] or 626-918-5719
1949 SUBURBAN
Thanks John! I am still somewhat torn between fixing the rust and wear damage on this frame or stretching a GM 4x4 frame and going with a modern drivetrain. I have your info saved and will let you know.
1949 "Heinz 57"
