| | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | Has anyone seen a source for the cast spring perches that are riveted to the frame? My rear frame mounted spring perches are worn so much that new bushings wouldn't last a mile.
I could fab new ones from plate steel, but I'd rather replace with original style.
49 Chevy.
1949 "Heinz 57"
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Used is about the only route you're going to be able to get them. I'd suggest checking in the Parts for Sale, or hit the local salvage yards.
Bill Burmeister | | | | | Joined: Oct 2004 Posts: 348 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 348 | I have a set for $25.00 plus $10.00 shipping you can contact me at [email protected] or 626-918-5719 | | | | | Joined: Jan 2007 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 79 | Thanks John! I am still somewhat torn between fixing the rust and wear damage on this frame or stretching a GM 4x4 frame and going with a modern drivetrain. I have your info saved and will let you know.
1949 "Heinz 57"
