1 members (Hotrod Lincoln),
41
0
Mod | | | Forums66 Topics128,035 Posts1,055,560 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2006 Posts: 70 'Bolter | | 'Bolter Joined: Jun 2006 Posts: 70 | I was replacing the three broken/missing heater cables today in my '58 and got the defrost and inside/outside air cables o.k. but when installing the missing temp cable, I could not locate where the cable from the dash control goes to. There is no referance to the heater in the factory assembly manual so I thought I'd see if anybody knew. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | There should be a valve in one of the heater hoses, probably under the hood. It's possible your valve corroded so much it became un-usable and was removed by a previous owner. Universal valves are available at auto parts stores.
The reason there is no mention of a heater in the assembly manual is heaters were a dealer installed or after market item in those days. | | | | | Joined: Jan 2008 Posts: 33 New Guy | | New Guy Joined: Jan 2008 Posts: 33 | on my 55nd the heater control valve is located at heater core. this is the deluxe fresh air heater, which is propably what you have
1955 CHEVY 3600 TF
