6 members (68ironhead, cmayna, Eisenholtz, joe apple, JW51, 66flea), 70 guests, and 1 robot.
Topics128,023
Posts1,055,367
Members48,420
#379219 02/24/2008 12:15 AM
I was replacing the three broken/missing heater cables today in my '58 and got the defrost and inside/outside air cables o.k. but when installing the missing temp cable, I could not locate where the cable from the dash control goes to. There is no referance to the heater in the factory assembly manual so I thought I'd see if anybody knew.
There should be a valve in one of the heater hoses, probably under the hood. It's possible your valve corroded so much it became un-usable and was removed by a previous owner. Universal valves are available at auto parts stores.
The reason there is no mention of a heater in the assembly manual is heaters were a dealer installed or after market item in those days.
on my 55nd the heater control valve is located at heater core. this is the deluxe fresh air heater, which is propably what you have
1955 CHEVY 3600 TF
