5 members (Wheelie, Gdads51, klhansen, greenie-reddy, 1 invisible), 87 guests, and 3 robots.
Topics128,036
Posts1,055,452
Members48,422
#379230 02/24/2008 12:43 AM
I added dropped coils to the front of the truck. I like the way it sits but it hits the top of the rubber stops. If I put the original springs back in,(I had cut off 1 1/2 coils off to lower it) do you think that dropped spindles will help?
Robert C.
I'm a Genius in the making.
1950 3600
Mobileortho #379242 02/24/2008 1:21 AM
U
U Offline
First: you should never cut coil springs.
Second: you need to change your bump stop rubbers to a lower type.
Third: whats up with the missing front swaybar?
Fourth: drop spindles are expensive, but seem to help keep all the stock geometry while giving you the ride hieght you desire.
underdog #379258 02/24/2008 2:03 AM
What underdog said. But then rodders have been cutting coils for as long as coils have been around. It's a cheap-and-dirty way of lowering. 1 and a half coils isn't excessive. I'd look for a different bumper arrangement. OR - since this isn't working anyway, cut the bumpers in half, or maybe even a little more, and give it a try - what have you got to lose?
The bottom A-arm looks pretty level, that's good, but the steering tie rod is tilted up towards the wheel, this may leave you with some bump-steer. Again, try it out first, then look for a solution if it isn't working right. You might be able to flip the tie-rod end at the steering arm, letting it ride under the arm and thus leveling it out, or heat and bend the steering arm down.
Dropped spindles eliminate most of the problems encountered with lowered cars/trucks, but they are spendy $$$$.
waldo53 #379307 02/24/2008 3:49 AM
The swaybar will be added after I buy new bushings. Will try to cut the bumper stops down a bit to see how that works. Waldo, thanks for the info on the A-arm.
Robert C.
1950 3600
Mobileortho #380585 02/27/2008 3:10 AM
Just found some more bumpers. Looks like I can us the same ones from the top which are about half the height of the bottom ones.
Robert C.
1950 3600
Mobileortho #384670 03/07/2008 6:13 AM
Eather change the bump stops for shorter onesor cut the bump stop down. I've seen worse but what bothers me is the angle of the tierods. It may give you some bumb steer. If your not useing the swaybar anymore take the mount off.
37truckman #384786 03/07/2008 4:02 PM
Truckman, you must have looked at old pics when I was addressing the bump stops. New pics show the shorter bump stops & sway bar installed.
Robert C.
1950 3600
waldo53 #384873 03/07/2008 7:26 PM
I looked at flipping the tie rod but the hole in the spindle is tapered to match the bolt on the tie rod. I dont know if drilling it out will cause problems or not.
Robert C.
1950 3600
