3 members (homer52, 3B, 1955 1 Series), 137 guests, and 2 robots.
Topics128,195
Posts1,057,369
Members48,469
Junior Member
Junior Member
well last friday did the brake job on the 50 chevy panel truck,made several ROAD TESTS, this week one over 20 miles, then wed. eve, start down the road go about a mile hit the brakes and THEY GO TO THE FLOOR!!!!!!!make it bake home without dents or dings,,,,,,,look under truck the drivers side rear wheel cyl. blew out???? took off wheel and drum and the clip off of pin they holds the brake shoes together had come off, checked the other side the same way????( but did not come out)they were new clips from OBSOLETE CHEV......put another new set of clips on last night ,re- bled brakes adjusted and went on a 30 mile round trip test ride!!!!!!yes i love ridding in the old panel....anyone had problem with clips coming off the pins in bottom of the brake shoes??????????/thanks for all answers
1950 Chevy Panel 310
only when i've put them on wrong..
Driving without brakes is an experience to be remembered. eek If there is no one else on the road it can actually be fun. grin As long as the pins are in good shape, the clips don't come off if you install them right. wink
Fred
52 3600
69 C-10
