9 members (Nhluvstruck, 32Fordpuchoptop, Bill Hanlon, DHedrick, Ponchogl, Southerntruck, Otto Skorzeny, 1955 1 Series, 1 invisible), 125 guests, and 0 robots.
Topics128,114
Posts1,056,283
Members48,439
#37896 01/23/2004 5:56 PM
If i were to change rearends in my 54 1/2 ton, and keep my 235 motor, what would i be looking for that would be the simpliest to drop in. i know i have to ditch the torque tube but what else am i looking at? is it cheaper to just buy the conversion kits for the existing rearend?. all i am looking for is daily driver stuff but be able to run the speed limit out on the highways and byways.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#37897 01/24/2004 2:24 AM
If I'm not mistaken, torque tube setups use a transmission that bolts to the torque tube. Non-TT transmissions are easy to find. You'll need a driveshaft, too.
1954 GMC De Luxe COE
#37898 01/24/2004 4:25 AM
A friend of mine has a '54 with transmission, driveshaft and rear axle from a '58, or at least that is what he was told.
#37899 01/26/2004 5:41 PM
i was actually asking about a car rear end, like a nova or camaro. which ones are the easiest to drop under? someone mentioned a s10 rear end in an earlier post???
#37900 01/26/2004 5:56 PM
The PO of my 54 truck swapped a 1973 4WD chevy 12 bolt rear. Looked like that was easy except for new shock mounts on the frame. But he also put in a later sm420 trans and built a drive shaft.
if it dosen't need fixed, break it
