1 members (CuzzFuzz), 83 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
when i replace the head gasket on this 216 will i need to apply a gasket sealer.......with v blocks some i do and some i dont...just curious if this 216 is a little different.......thanks all
H Online: Content
The only time I use a sealer on a head gasket is when it's a single-layer steel shim type of gasket. The composition-type, or the "no retorque" gaskets already have a sealer built in. The best head gasket sealer I've found is a brush-on liquid, Permatex Super 300. It's a thick, almost black liquid, not the runny 3D type. It was developed for use with parts exposed to aviation gasoline back during WW II. Hard to find, but good stuff!
No need for gasket cement/sealer on your engine.
Harvester
thanks guys.........i thought i would get reactions from both sides..........what i really need is someone to bring up some heat to iowa........is it cold up here or what.........i cant wait to get back to florida.....
Personally, because I feel changing head gaskets is a bit of a hassle, I use the Permatex copper spray sealant on my gaskets before I put them on any engine, regardless of the type of gasket. Seems to work good, last long time. And improve sealing too.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
Ex Hall Monitor
Ex Hall Monitor
I don't claim to be an expert but I didn't use sealant on my 216 & haven't had a problem. Just torque it to spec. & you shouldn't have a problem.
Hot rod dad....i see your holding a 68 corvette...i started my 68 corvette collection 20 years ago.......ive aquired 4 over the years.....3- 427-435 tripower and 1 427-400.....they are getting harder to find these days and thank god the 68 was my favorite year and not the 67.......the 68 was also the most narrow out of all the corvettes...out of all my antique autos the 68s are my favorite.....nice sunny day pull the top down and cruse down the road.........but the trip is short because of the price of aviation fuel......i take a drive to the local resturant and drive back and ive used 20 bucks worth of fuel...and thats just taking it easy....well thank you all for the information on the gasket......your input is always appreicated
