1 members (CuzzFuzz), 228 guests, and 6 robots.
Topics128,101
Posts1,056,181
Members48,436
#37885 02/20/2005 11:26 PM
Hi Fellow Bolties! Can someone tell me on a 216, how to take out the copper oil line that comes from the block, and feeds oil up to the rocker arms / shaft? The line looks ok, but someone has dammaged the brass fitting that threads the line into the block. I tried to take it loose, but the line just turns and won't come out. Also, same for the smaller line on the left side of the block. Thanks for any advice.
KT
1949 3/4 ton. 1950 1/2 ton
1953 3100 with 1957 235, T5 and 12 bolt 373 rear
#37886 02/21/2005 1:19 AM
The oil line on the left side and on the right side is the same bit of tube .
It is replaced complete as a unit.
If you are lucky you can reuse the brass fittings , otherwise try your local NAPA or Jim Carter for the fittings .
#37887 02/21/2005 6:16 PM
kt,
check your Email. I sent you a pdf .
Fred
1951 1 Ton Completed
#37888 02/21/2005 6:57 PM
Jed Offline
KT, not to horn in on your topic, but I'm a bit confused. Could someone post a picture of what tube you're talking about. I've just finished putting a 216 in my 46 1/2 ton, and I don't have lines out of both sides of the block. Come to think of it, on the old motor either. I'm getting concerned now though, as the one line I do have was a brass fitting, and I had to replumb the line as it wouldn't clear the exhaust. It took some work to get it out of the block, but it came out with the brass fitting. Now, I'm wondering if I might have broken something off in there? I have an oil leak around the fitting, when the motor's running, but I thought it was merely needing to tighten up the new fittings. I'm going to have to take the manifold off to get to them, and at that point, it won't be "runnable" until I put them back on. I sure don't want to have to take all of this stuff apart multiple times. Thanks for any information you can share.
#37889 02/21/2005 9:18 PM
Jed,
I am at the wrong computer but I will send you the PDF file that I sent KT. On these old 216s, down on the driver's side of the block, there is a small plate held on by several bolts. Right behind that there is a small tube that somes out of a fitting, loops around and goes back into the block.(I think that I have a picture of that somewhere too.)The tube actually goes through the water jacket and comes out the other side underneath the side cover. From there the feed goes up and connects to the rocker arm
#37890 02/21/2005 10:02 PM
Jed Offline
Thanx Truckernix. I'd be very curious to see that, because I think I may have a major problem now. I thought I had merely disconnected the plumbing on the side of the block and simply needed to replumb it. Now it seems as though I might have broken that tubing when I pulled it out, and will have to tear something else down to replace it. Do you or someone else know how difficult this process might be. Also, is it plumbed the same way on all 216's? The box on the side of the block and the routing of the tubing on 46 block I pulled out of the truck looks considerably different than the 39 block I put back in. Am I as hosed as it sounds like I may be? Please please say it isn't so...
#37891 02/22/2005 3:32 AM
Thanks to all who replied with help!! I had never had one of the lines out. I got it out tonight. I will try to locate one. Truckernix, I didn't know it was a special line. I was hoping I could just get the copper line, and the fittings and ferrels. I will check with Chevs of the 40's!
Thanks again all!
KT
#37892 02/22/2005 4:29 AM
I found the directions for installing a new line. They are on page 6-38 of the Chev Truck manual under "rocker shaft oil line pipe".
#37893 02/22/2005 8:34 AM
KThomas and Jed, I do not know if this is what you are looking for but on EBay this oil piping system is up for bid. web page I hope this may help either one of you.
Jamo smile
Growing old is manditory-Growing up is optionial.
Jamo
http://community.webshots.com/user/erics46
#37894 02/22/2005 2:51 PM
That Ebay item appears to be the piping for the dipper sprayers. That is not the part that we are talking about but it is very interesting to look at. For anyone that has not seen the inside of one of these oil pans, those nozzles actually fit down inside the troughs used by the dippers.
#37895 03/07/2005 9:08 PM
Jed Offline
Just wanted to say thanks to all of you guys for the valuable information. I was able to replumb the oil lines this weekend. Wasn't near as difficult as what I dreaded it might be. Am working to resolve some clearance issues with my recently split manifold now, and then off to the exhaust shop and down the road. At least that is my hopes. Thanks again for the help!
