2 members (Uncles51, Lostbuthaulinass), 79 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#37881 09/05/2003 4:28 AM
Hey guys, I just got a 51 3100 with a 216. It has not been started for 10 years. I changed the oil but I know the mains have got to be dry. How do I get the mains lubed before I start it? Should I over fill it and hand turn the engine, then drain it down to the correct amount? If so how much oil should I put in it? Is there a better way?
1951 Chevy 3100
Some days you get the bear. Some days the bear gets you.
#37882 09/05/2003 1:45 PM
Don't overfill the crankcase. Easyiest way to pre-oil is to turn off the fuel, remove the spark plugs, disconnect the coil wire and spin it with the starter. About a minute should do it.
Fred
52 3600
69 C-10
#37883 09/05/2003 10:31 PM
Thanks Fred. I'll give it a try.
1951 Chevy 3100
#37884 09/10/2003 4:09 PM
I'd put a little light oil in each spark plug hole before I spun it, if it was me. A couple of teaspoons at most. The idea is to wet the rings and walls as you crank it.
You may foul the plugs a bit when you finally start it, but they're easy to clean. Why risk ring/cylinder damage for the price of a plug?
Good luck!
George
