3 members (Lostbuthaulinass, Otto Skorzeny, Nick in Manitou), 81 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#3783 07/13/2004 1:18 PM
Where do I find the casting date on my 1950 engine block. I can find the casting # and the vin but not the casting date.
#3784 07/13/2004 3:11 PM
If it's a 235 then snuggled up next to the starter should be the castings. Mine says B 262. Meaning it was casted Feb 26, of 1962. You need a strong flashlight and a retired tooth brush to clean up the area really well. Keep scrubbing and scraping. It will be there.
Craig
#3785 07/13/2004 4:12 PM
I have a 235 in the truck and a 216 for parts. I'm trying to find the date on both. Is it located in the same place for both engines?
#3786 07/13/2004 5:34 PM
Same general area near starter. It may be behind it requiring removal to see numbers.
Professional Novice
#3787 07/13/2004 6:17 PM
Here's a shot I just took of mine. White arrow is pointing to the elusive casting number while the stamped (assembly) number is to the right....
http://community.webshots.com/photo/127846177/162769123lxQlod
Craig
#3788 07/13/2004 11:19 PM
Y
Y Offline
