| | | Forums66 Topics128,021 Posts1,055,372 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | Where do I find the casting date on my 1950 engine block. I can find the casting # and the vin but not the casting date. | | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | If it's a 235 then snuggled up next to the starter should be the castings. Mine says B 262. Meaning it was casted Feb 26, of 1962. You need a strong flashlight and a retired tooth brush to clean up the area really well. Keep scrubbing and scraping. It will be there.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
| | | | | Joined: May 2004 Posts: 105 'Bolter | | 'Bolter Joined: May 2004 Posts: 105 | I have a 235 in the truck and a 216 for parts. I'm trying to find the date on both. Is it located in the same place for both engines? | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | Same general area near starter. It may be behind it requiring removal to see numbers.
Professional Novice
| | | | | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | Here's a shot I just took of mine. White arrow is pointing to the elusive casting number while the stamped (assembly) number is to the right.... http://community.webshots.com/photo/127846177/162769123lxQlod
#3788 07/13/2004 11:19 PM | Joined: Jul 2003 Posts: 252 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 252 | | | |
