5 members (Gib70, KEVINSKI, Phak1, 1955 1 Series, amtrakjoe), 136 guests, and 2 robots.
Topics128,092
Posts1,056,451
Members48,443
We're going to do a compression check on my son's '62 today. What kind of range is considered "normal" for this engine, and what numbers will tell us that we have a problem?
(I mean besides zero! wink )
Thanks in advance.
Then you will know the truth, and the truth will set you free.
- Jesus -
I just did mine. I got 130 -120 on all cylinders.
The book say the cylinders should all read the same +- 10psi. It depends on the kind of gauge you use I use a screw in the press on ones must read lower. But I would worry about any readings below 90.
if it dosen't need fixed, break it
I have a Feb '62 built 235 in my '50 deluxe cab and recently did a comp test with the results being 120-122 pounds.
Craig
do it warm and block open the throttle to get consistant results.
Paint & Body Shop moderator
No more than 10psi variance for a good balance.
Thank you all. We didn't get to it last night. We spent too much time trying to find the little timing mark on the flywheel. Never did find it.
- Jesus -
Thats why I mentioned the dial-back light.. Twist the knob, and the ball shows up. If the timing is too advanced or too retarded, it'll be out of the window... literally!
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
