3 members (baldeagle, Jon G, Oswald), 63 guests, and 4 robots.
Topics128,015
Posts1,055,334
Members48,419
#377300 02/19/2008 2:34 PM
Is a carter 966s a good replacment carb for a stock 1955 235?
I know the YF is but I dont know if the 966s is for a chevy or something else? someone told me a 2100s is what I need. looked on carb kings site, couldnt find anything on the YF?
1965 chevy c-80 409 5-2 20000 original miles.
1965 chevy c-60 348 5-2 single axle tractor.
1952 chevy p/u 235 4 speed restored.
1965 chevy c-60 couch.
One grouchy wife. FOR SALE....CHEAP!!!!
The future is not what it used to be.....
Have a new pair of metric vise-grips and large metric hammer, can fix anything...
Mr Goodwrench #377340 02/19/2008 4:11 PM
The Carter 964s is the stock number for the carb that chevrolet indicates for the years 1937 through 1952. It came with initial venturi size of 1 1/32" and secondary venturi at 11/16 id. and the main venturi at 1 1/4" id. . I don't know the specs of the 966s but perhaps you can find it in the Carter Carbutetor information for Chevrolet and GM on line. I have been looking at the YF series 2467 to modify for my 235. I believe the 964 is a size 2 and the 2467 is a size 3 so the issue is the venturi sizes and the vacuum. Too big a venturi and the carb will run lean...not a optimum. Bigger is not always better or more effective, less vacuum may not excite the venturi adequately...especially if you are looking at dual carbs. I know there are some pretty carb wise guys out there so I am pretty interested in some replies about this as I am tinkering around myself.
B_H54 #377497 02/19/2008 11:56 PM
-Tom
1950 Chevy 3100 w/ 1956 235
B_H54 #377607 02/20/2008 3:07 AM
Carburetion specialist
There are two excellent reasons NOT to do this:
(1) This thing is calibrated for a MUCH smaller engine, and would require major modifications to work well on a 235.
(2) Since this is a highly sought after unit for the Willys Jeep, it is worth at least double the value of a Chevrolet carb. Find a Willys guy and he would probably trade you 2 for one!
Jon.
The Carburetor Shop
carbking #377840 02/20/2008 5:23 PM
Jon.. thanks for the reply. The learning curve on this site is pretty steep, especially for the infrequent user. The info you posted is wonderful, and I really appreciate your time to do so. I recently just became a Chevy guy , having been a willys guy for long time. I thought the l-226 was a similar enough engine to warrant tinkering with th YF. Having a box of these seemed like a good resource for a project. Thanks again for setting me straight.
B_H54 #377856 02/20/2008 6:07 PM
Thanks for all the help guys!!!! guess I better keep looking for a 2100S
Mr Goodwrench #378310 02/21/2008 7:01 PM
In my Carter Carb. book a 966-s is listed as a replacement carb for all 1950-52 235 engines in cars and trucks. It should work fine.
