9 members (Tronman, tclederman, Bill Hanlon, Otto Skorzeny, Hotrod Lincoln, carbking, 49choptop, Guitplayer, John L.),
145
Mod | | | Forums66 Topics128,042 Posts1,055,501 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | Is a carter 966s a good replacment carb for a stock 1955 235? I know the YF is but I dont know if the 966s is for a chevy or something else? someone told me a 2100s is what I need. looked on carb kings site, couldnt find anything on the YF?
1965 chevy c-80 409 5-2 20000 original miles. 1965 chevy c-60 348 5-2 single axle tractor. 1952 chevy p/u 235 4 speed restored. 1965 chevy c-60 couch. One grouchy wife. FOR SALE....CHEAP!!!! The future is not what it used to be..... Have a new pair of metric vise-grips and large metric hammer, can fix anything...
| | | | | Joined: Jan 2008 Posts: 17 New Guy | | New Guy Joined: Jan 2008 Posts: 17 | The Carter 964s is the stock number for the carb that chevrolet indicates for the years 1937 through 1952. It came with initial venturi size of 1 1/32" and secondary venturi at 11/16 id. and the main venturi at 1 1/4" id. . I don't know the specs of the 966s but perhaps you can find it in the Carter Carbutetor information for Chevrolet and GM on line. I have been looking at the YF series 2467 to modify for my 235. I believe the 964 is a size 2 and the 2467 is a size 3 so the issue is the venturi sizes and the vacuum. Too big a venturi and the carb will run lean...not a optimum. Bigger is not always better or more effective, less vacuum may not excite the venturi adequately...especially if you are looking at dual carbs. I know there are some pretty carb wise guys out there so I am pretty interested in some replies about this as I am tinkering around myself. | | | | | Joined: Apr 2006 Posts: 506 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 506 |
-Tom
1950 Chevy 3100 w/ 1956 235
| | | | | Joined: Nov 2002 Posts: 2,763 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,763 | I have been looking at the YF series 2467 to modify for my 235. There are two excellent reasons NOT to do this: (1) This thing is calibrated for a MUCH smaller engine, and would require major modifications to work well on a 235. (2) Since this is a highly sought after unit for the Willys Jeep, it is worth at least double the value of a Chevrolet carb. Find a Willys guy and he would probably trade you 2 for one! Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Jan 2008 Posts: 17 New Guy | | New Guy Joined: Jan 2008 Posts: 17 | Jon.. thanks for the reply. The learning curve on this site is pretty steep, especially for the infrequent user. The info you posted is wonderful, and I really appreciate your time to do so. I recently just became a Chevy guy , having been a willys guy for long time. I thought the l-226 was a similar enough engine to warrant tinkering with th YF. Having a box of these seemed like a good resource for a project. Thanks again for setting me straight. | | | | | Joined: Feb 2008 Posts: 40 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 40 | Thanks for all the help guys!!!! guess I better keep looking for a 2100S
| | | | | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | In my Carter Carb. book a 966-s is listed as a replacement carb for all 1950-52 235 engines in cars and trucks. It should work fine. | | |
