Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, Wayne67vert), 159 guests, and 5 robots.
Topics128,281
Posts1,058,471
Members48,490
#37787 08/14/2002 2:35 AM
I was wondering what it would take to swap a 350 into my 56 chevy 2 door sedan, right now it has the 235 and the 3 on the tree. I plan on keeping the 3 spd. in it for quite a while, at least until i start restoring the car. The 350 that i plan on putting in the '56 is now hooked up to an automatic in a 74 3/4 chevy pickup...
i was thinking the only thing id need would be a bellhousing, and motor mounts.....
any help would be greaty appreciated
55 2 dr 210- after college project
56 2 dr 210- after '55 project
"D'oh"
#37788 08/14/2002 11:30 PM
Along with the bell housing, you may need to use a little bigger radiator.You may also need to find or make a different driveline and set up the exhaust and linkages. cool
