4 members (Peggy M, Otto Skorzeny, klhansen, farmallb), 107 guests, and 2 robots.
Topics128,041
Posts1,055,487
Members48,424
#377083 02/19/2008 12:53 AM
I've looked high & low and need some help. Is the 235 bellhousing the same regardless of the tranny behind it? Any help would be greatly appreciated.
1948 Chevrolet 1-Ton Grain Truck
In the Stovebolt Gallery SOLD
More pix in Photobucket
"A Man & His Truck--It's a Beautiful Thing!"
"You're never 100% ready, you're just next"....Ty Murray
3B Offline
Hy a.d.-hawk, I believe all the truck housings are the same, the car housings are different in many ways, hope that helps.
That does, 3B. I'm interested in changing out the 4 speed for a T-5. I figured they were. I've run into many differences between a 3100 & 3600, and thought maybe that there was a difference between this too. Thanks.
The bellhousing and the cross member it rests on changed in 54. The mounts are slanted or angled instead of flat.
Professional Novice
Thanks Frank. If I choose to redo the original clutch, are they pretty difficult & expensive to replace?
I went back to read about your truck & noticed you mentioned that your truck had '76 plates on it when you bought it. So does mine. Did everybody just park their old trucks in the mid-'70s?
Seems that way. The first old Chevy pickup I bought back in 99 (55-1st) had 78 plates on it. Maybe 20-25 years was considered a useable life-span for a car or truck back then. Go figure....
Professional Novice
Riding in the Passing Lane
The mid 70,s had a severe gas shortage & economic recession. That might have had something to do with it.
1972 Chevy c10 Cheyenne Super
My question is similar to this one... I have a 250 L6 in my '69 Chevy C-10, with a 3 speed B&W OverDrive out of (what I was told) was from a late 50's Chevy.
Will the Borg & Warner 3 speed bellhousing bolt up to an S-10 T5?
Also, will I be able to use the clutch/ flywheel?
thanks!
- Joe
stupid like a fox
art and junk: sandiegojoe.com
In response to Joe, The bellhousing has the same bolt pattern, flywheel will be OK, probably need a different clutch for the T5. There are differences in the OD transmissions, if you have an early one with a 4 bolt side cover it has a non syncro first gear. The later one is a Saganaw, full syncro, 7 bolt side cover. If you have a late trans it is probably more of a heavy duty unit than the T5. If your current OD works you probably won't gain much for the expense of the conversion.
Fred
I think that some S10s that had the big V6 used a T5 with a regular Chevy bolt pattern. The small V6 and 4s have a different pattern. I put one of the latter in my '53 Chevy 1/2 ton with a 270 GMC in it. I made a 3/8 adapter plate,had to change the clutch plate,and build a rear mount. With truck length shifter the pattern is wide. I'm working on that. It was not as easy as I thought it would be as the top tranny bolts are too near the original holes. If you use the V8-big V6 T5 it will bolt up but you have to shorten the input shaft 3/8". Also you must use an S10 rear housing or your shifter will be in your seat. Well, not yours but your truck's. If your 3 speed OD is a Saganaw and it works I'd keep it. If it doesn't work I'd fix it. There are several different 3 speed ratios. You can also put that OD on a Saganaw 4 speed. Hot Rod magazine May 1970, I think, had an article. Mine works well but I wouldn't do it again. By the way if yours is a Saganaw 3 speed OD and you decide to replace it I'd like to buy it OD working or not. Good luck!
"I wonder if God created man because he was disappointed in the monkey?" Mark Twain
