3 members (TexasJim50, Peggy M, TexasA&M48Truck), 105 guests, and 6 robots.
Topics128,094
Posts1,056,058
Members48,433
#37760 09/22/2002 12:50 AM
My 4 speed tranny started pooping out of 3rd gear. Not too often just every once in a while. Is it some kind of bearing I could do my self? Sorry I don't know what kind it is.
57 3100 235 3 spd
#37761 09/22/2002 2:15 AM
Anonymous
Unregistered
Anonymous
Unregistered
Sounds like a brass syncro is history. Be glad its not 4th gear. Keep using it like it is & ride third gear until you get the RPM's for 4th.
#37762 09/22/2002 4:28 AM
Anonymous
Unregistered
Anonymous
Unregistered
MT, my 4400 dumptruck sounds like a siren in granny gear when I let off the gas, quite a bit quieter when under load or accelerating, but still noisy - then when I get into second it quiets right down, but pops out of gear all the time, in fact, I can barely hold it in 2nd and still drive. What do you suppose is wrong with it? Quiet and smooth in 3rd and 4th. PTO is also relatively quiet. . . I have a 4 speed out of a same year (52) GMC 1/2 ton - will it fit?
#37763 09/24/2002 5:26 PM
Thanks for the replies. Guess it will get worse over time. I'm not real comfortable w/ working on trannys. Any idea what a bearing or synchro job might cost?
57 3100 235 3 spd
#37764 09/24/2002 5:50 PM
Looking at my bill. It is something like $500 plus parts.
if it dosen't need fixed, break it
#37765 09/24/2002 10:17 PM
Man! That much?
57 3100 235 3 spd
#37766 09/25/2002 12:51 AM
You bet: With the new clutch, pressure plate, through out bearing, main shaft, bearing kit and stuf. The hole bill was $1265. I'm doing every thing else myself.
#37767 09/25/2002 3:10 PM
Now for option 2. I just bought a 57 3100 235 3 on the tree. Doing the same thing in 3rd. Good luck, huh? How hard are these three speeds to rebuild? Is there a book or something I can buy?
57 3100 235 3 spd
#37768 09/25/2002 4:24 PM
The factory shop manual will take you through the rebuild process. I would stay with the four speed.
#37769 09/25/2002 6:20 PM
Good,I should be receiving my manual any day. Thanks
57 3100 235 3 spd
#37770 09/26/2002 5:59 AM
Ken: It sounds like your noise is possibly a bearing problem. If the bearings are bad enough, they can also cause a shifting problem or a popping out of gear situation. I have seen bearings bad enough that when you try to shift the shaft will actually move instead of the slider that ingages the gear, so it never really ingages fully. Thus, it pops out of gear.
'54 3100-235-T5 trans-12 bolt 3:31
'68 Impala 307/350
'78 Sportster/Original owner
