| | | Forums66 Topics128,078 Posts1,056,022 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#37744 04/08/2004 6:47 AM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | ALOHA!!!! OK I'm looking for bolt-on overload springs for when I tow my trailer and was wondering if anyone has fit "hellwig" or maybe another manufacturer's springs to 1951 stock, 2" wide, 1/2 ton springs? Or maybe another idea but I'd like to keep this Carryall Suburban as original as possible, thats why i say "bolt on". Spoke to "hellwig" directly and they didn't offer much help is also why I'm asking. Many Mahalo's
The objection to Puritans is not that they try to make us think as they do, but that they try to make us do as they think. H. L. MENCKEN | | |
#37745 04/08/2004 3:51 PM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The spring width should be 1.75" if stock.
See the USA in your vintage Chevrolet! My Blog | | |
#37746 04/12/2004 6:30 PM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | OK so their "one and three quarts", (I quess it's like a 2X4 isn't really 2" or 4", it's actually closer to 1 7/8's) anyone now able to help me out? Mucho Mahalo's | | |
#37747 04/12/2004 10:01 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Why don't you visit a spring shop? I'm sure they could fix you up with some progressive overloads that won't affect your ride when you are not loaded. I have a set on my truck, but they were there when I got it. They contact the frame through some pads when there is over about 500 lbs in the bed.
#37748 04/13/2004 1:45 AM | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Kimo, you might also ck. with a trailer shop. A lot of trailers use the 1.75 spring width. Dennis
40 Chevy 1/2 ton
#37749 04/13/2004 5:02 AM | Joined: Feb 2004 Posts: 85 Member | | Member Joined: Feb 2004 Posts: 85 | Aloha, Yeah i called "Long Beach spring and forge" and they want $150 per spring, read $300! still have 1 more place I know of, "warren spring" to call, if any Los Angeles area locals know of a good place please advise, But keep in mind bolt on Hellwig kits run about $125 total.
Ok the plot thickens, called "hellwig", they don't have anything that narrow but I gave them dimensions from my trusty GM "restoration package" and they gave me a part that is used on fjord rangers '98-'04 but I'll have to fabricate spacers to fit between the U-bolts and genny springs, shouldn't be a problem, If anyone cares I'll keep ya posted on the outcome.
ALOHA NUI LOA | | |
