3 members (Nick in Manitou, UtahYork, Bill Hanlon), 78 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#37744 04/08/2004 6:47 AM
ALOHA!!!! OK I'm looking for bolt-on overload springs for when I tow my trailer and was wondering if anyone has fit "hellwig" or maybe another manufacturer's springs to 1951 stock, 2" wide, 1/2 ton springs? Or maybe another idea but I'd like to keep this Carryall Suburban as original as possible, thats why i say "bolt on". Spoke to "hellwig" directly and they didn't offer much help is also why I'm asking. Many Mahalo's
The objection to Puritans
is not that they try
to make us think as they do,
but that they try to make us
do as they think.
H. L. MENCKEN
#37745 04/08/2004 3:51 PM
The spring width should be 1.75" if stock.
My Blog
#37746 04/12/2004 6:30 PM
OK so their "one and three quarts", (I quess it's like a 2X4 isn't really 2" or 4", it's actually closer to 1 7/8's) anyone now able to help me out? Mucho Mahalo's
#37747 04/12/2004 10:01 PM
Why don't you visit a spring shop? I'm sure they could fix you up with some progressive overloads that won't affect your ride when you are not loaded. I have a set on my truck, but they were there when I got it. They contact the frame through some pads when there is over about 500 lbs in the bed.
Paint & Body Shop moderator
#37748 04/13/2004 1:45 AM
Kimo, you might also ck. with a trailer shop. A lot of trailers use the 1.75 spring width.
Dennis
40 Chevy 1/2 ton
#37749 04/13/2004 5:02 AM
Aloha, Yeah i called "Long Beach spring and forge" and they want $150 per spring, read $300! still have 1 more place I know of, "warren spring" to call, if any Los Angeles area locals know of a good place please advise, But keep in mind bolt on Hellwig kits run about $125 total.
Ok the plot thickens, called "hellwig", they don't have anything that narrow but I gave them dimensions from my trusty GM "restoration package" and they gave me a part that is used on fjord rangers '98-'04 but I'll have to fabricate spacers to fit between the U-bolts and genny springs, shouldn't be a problem, If anyone cares I'll keep ya posted on the outcome.
ALOHA NUI LOA
