1 members (porsche),
111
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,051 Posts1,055,767 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | guys, does anyone know the overall tire width on rear of 54' chevy cabover? outside to outside of rear duels is what i need to see if we need to remove outer rear duel for trailer as we have 7'3" between fenders. also need length of body cab foward for moving purposes.their is pic's of truck on my webshots.thanks!  | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | joe, their is pic's on my webshots i'm not sure if it's 4100,4400,4502 or 5000 up let me know if you can tell by the pic's. well 7'3" is 87" so sounds like we won't have to remove the rear outer wheels. thanks
| | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | just found out the truck is a 5700 and the front track width is 6', would this truck have come with a 235 or ? thanks | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | A '54/'55 Chevy COE, can have either a 235, or 261ci. engine. Check for the casting no., on the passenger side of the block, to the front of the dist., around the area, of the fuel pump. I just went out, & measured the rear wheels, on my '53 Chevy COE with 9.00 X 20's, on the rear, & the outer tire measurements, from sidewall, to side wall were 92"in., & the inner tire measurement was 72"in. This will vary, depending on the size tires, on your truck. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I have had a 161" wheel base 48 Chevy 6400 on our 18' flat trailer several times, the front fits just fine, and the rear tires stay behind the trailer fenders, so even though they are to wide to fit between it makes no difference, as they don't have to. I can dig up a picture if it would help any?
Grigg | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Hey Grigg, that looks like Quinn, SD area in the background!
Bruce | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Hey Grigg, that looks like Quinn, SD area in the background!
Bruce Exactly! My 6400, that I found on this page with a wanted add, use to live there. Quite a trip to go fetch it, but worth it I think. Grigg | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | What do you mean long trip.......it's only 70 miles!
Bruce | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 77 9/16" across front fenders
79 13/16" outer center tread on rear axle + 6 5/8" to outside of tires
Remove the outer wheels and the rear width is 69 1/16"
38 1/8" from front axle to front of bumper
The standard tires/wheels were 7.50 x20 (6.0 rim section)
As Spanky indicated, 235 Loadmaster was standard engine on a 5700 and a 261 Jobmaster was the optional engine. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | is a 5700 considered a 2 ton truck? the designations of the "4000+" series is greek to me,enlighten me thanks. | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | A 5700 series COE, is indeed a 2 ton. | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | | | |
