0 members (), 80 guests, and 4 robots.
Topics128,062
Posts1,055,857
Members48,428
#376599 02/17/2008 9:54 PM
1 Offline
guys, does anyone know the overall tire width on rear of 54' chevy cabover? outside to outside of rear duels is what i need to see if we need to remove outer rear duel for trailer as we have 7'3" between fenders. also need length of body cab foward for moving purposes.their is pic's of truck on my webshots.thanks! smile
1 Offline
joe, their is pic's on my webshots i'm not sure if it's 4100,4400,4502 or 5000 up let me know if you can tell by the pic's. well 7'3" is 87" so sounds like we won't have to remove the rear outer wheels. thanks
1 Offline
just found out the truck is a 5700 and the front track width is 6', would this truck have come with a 235 or ? thanks
A '54/'55 Chevy COE, can have either a 235, or 261ci. engine. Check for the casting no., on the passenger side of the block, to the front of the dist., around the area, of the fuel pump. I just went out, & measured the rear wheels, on my '53 Chevy COE with 9.00 X 20's, on the rear, & the outer tire measurements, from sidewall, to side wall were 92"in., & the inner tire measurement was 72"in. This will vary, depending on the size tires, on your truck.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
I have had a 161" wheel base 48 Chevy 6400 on our 18' flat trailer several times, the front fits just fine, and the rear tires stay behind the trailer fenders, so even though they are to wide to fit between it makes no difference, as they don't have to.
I can dig up a picture if it would help any?
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
[IMG]http://thumb9.webshots.net/t/62/562/2/24/0/2298224000080251109AfIDdU_th.jpg[/IMG]
161" wheelbase 2 ton on an 18' trailer (16' flat, 2' turn down)
Grigg
---All pictures---
Hey Grigg, that looks like Quinn, SD area in the background! grin
Bruce
My Trucks
Stuff I Collect
Bruce
Exactly!
My 6400, that I found on this page with a wanted add, use to live there. Quite a trip to go fetch it, but worth it I think.
Grigg
---All pictures---
What do you mean long trip.......it's only 70 miles! grin
Bruce
My Trucks
Stuff I Collect
77 9/16" across front fenders
79 13/16" outer center tread on rear axle + 6 5/8" to outside of tires
Remove the outer wheels and the rear width is 69 1/16"
38 1/8" from front axle to front of bumper
The standard tires/wheels were 7.50 x20 (6.0 rim section)
As Spanky indicated, 235 Loadmaster was standard engine on a 5700 and a 261 Jobmaster was the optional engine.
1 Offline
is a 5700 considered a 2 ton truck? the designations of the "4000+" series is greek to me,enlighten me thanks.
A 5700 series COE, is indeed a 2 ton.
Spanky Hardy
1950 GMC 250 1-Ton
1 Offline
thank you!
