3 members (WICruiser, TexasA&M48Truck, Charles in CA), 63 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#377148 02/19/2008 3:18 AM
Brought my truck home from dry storage this weekend. I was off work today and mocked up the TPI, added the front shocks & removed excess brackets rom the frame. I added photos to my Webshots. I'm pleased with the results so far. I've added 3" drop coils to lower the front. Thinking of adding drop spindles as well. The stance looks pretty good to me for it being a '79 IFS. Now that it's back home I can tinker at my leisure. Hope to have it running this spring.
Robert C.
I'm a Genius in the making.
1950 3600
Mobileortho #377162 02/19/2008 3:34 AM
mobileortho:
Having it at home will really speed up the work and give you a place to escape to when mama's hot.
BTW I see you have removed the front sway bar. Gonna put another one back on? It also looks like you have your 4 gage set ready to install. Did it come with a sending unit? If not I have the one I bought from Brothers to go on my Blazer tank I would be happy to turn loose if you need it. eeeek
My new tank:
http://good-times.webshots.com/photo/2307964330099708909pjbkFA
~Jim
Mobileortho #377165 02/19/2008 3:36 AM
Apprentice
Apprentice
looks good! im interested in your motor mounts. are they solid or using a rubber mount also. I used a 71 frame but I have limited clearance in front of the engine using the stock mount location. I was considering making something similar to what you have there to move the engine rearward 3 inches or so. Keep up the good work!
sergent #377196 02/19/2008 4:21 AM
Big Chevy, I think my tank may be ruined. Looked in it and there is standing water about a 1/4" deep. Dont know how long it's been there but it's rusted pretty good. I'm going to attempt to clean it out. May switch to a plastic cell, or just put the original back in the cab. Sergant, I am going to put the sway bar on eventually. I need to go to the salvage yard to get the mounting brackets that mount to the frame. The motor mounts are stock (rubber). As you see from the photos I did not use the stock frame mounts, but custom tubes. It worked out really well.
Robert C.
1950 3600
Mobileortho #377249 02/19/2008 6:31 AM
I still have that Blazer tank if your interested. Freight would probably run around 28.00. Let me know
~Jim
Mobileortho #377255 02/19/2008 6:37 AM
Apprentice
Apprentice
right on, I just installed a 20 gal fuel cell in my frame from jegs. I had rust issues too so I opted for aluminum this time. it fit pretty well between the rails with a simple box I made up. All I can suggest for cleaning your old one out is do not use the vinegar method. I tried it and it was a waste of 40 bucks
sergent #377298 02/19/2008 2:33 PM
Hey sergent, got a camara? pix
~Jim
BIG CHEVY 3600 #377727 02/20/2008 6:24 AM
Big Chev, I'll keep your tank in mind. I haven't decided which route to take as of yet.
Robert C.
1950 3600
BIG CHEVY 3600 #378034 02/21/2008 2:04 AM
Apprentice
Apprentice
im trying to figure out how to add a picture to my post. any help? im using a mac if that will matter, thanks mike sergent
sergent #378079 02/21/2008 3:24 AM
"MONGO"
"MONGO"
sergent here you go...
IT Short Bus-->Showing off your Truck.
Mongo
