0 members (), 256 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
I've read that there are drop center rims in 19.5 and 22.5 diameter available with the 6 on 8.75 BUDD pattern which fit the old stovebolt trucks. It would be nice to get rid of the lock ring rims and run some radials. Good used 22.5s are easy to come by from truck tire shops. Anyone know where or what application used these wheels? I have heard that some F0rd F600s had them.
Jason
wich year, size, chevy are you talking about?
very few chevys trucks have the 6 on 8.75 BUDD pattern
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
1969 Chevy 3/4 ton 4wd
http://www.stovebolt.com/gallery/dahlin_luke_1969.html]1969 Chevy 3/4 ton 4x4
I don't know how many stovebolts have the 6 bolt BUDD wheels. I have a '56 with this bolt pattern. I was searching for a drop center replacement for my military truck and thought someone else may be able to use the info. I called a local truck salvage yard and they do have 22.5 diameter wheels with the 6 bolt on 8.75" diameter. Not as common as the hub centered style, but still available. $75 each.
Jason
yea I guess most army trucks had
6 bolt BUDD wheels but have not seen many normal old trucks like that
exept for older Dodges and a few Internationals
Luke Dahlin
1946 Chevy 2 ton
1966 Chevy 2 ton
