11 members (Rusty Rod, klhansen, David Bush, greenie-reddy, Cosmo, Lightholder's Dad, Peggy M, 3800GUY, Oswald, Wally / Montana, 1 invisible), 49 guests, and 1 robot.
Topics128,074
Posts1,055,911
Members48,429
#376833 02/18/2008 9:04 AM
Hi Folks.....can the ride height on a 1950's AD be lowered an inch or so without a complete transplant ? Lowering blocks with longer 'u' bolts work with leaf sprung cars, is this possible with a Chevy
truck ?
Best wishes.....Phil
Phil,
I am sure the experts will chime in soon & give ya all the info ya need on your conversion .
I do not see any major modifications needed to drop your ride an inch or so .
WELCOME TO THE BOLT !
Rad
1952 Chevy Shortbed
Photos in Photobucket
Lowering blocks will drop the rear end, but the front springs are on top of the axle so it will take a different approach. You could remove a couple leaves from the springs or get the springs de-arched. Ride quality would not be greatly affected with either method.
Removing the bottom 2 leaves on the front will drop the bumper about 1 1/2" and probably improve the ride. See the thread on steering wheel removal as it will be out about 90 degrees after that. For the rear you can use blocks.
You Tube
