7 members (klhansen, edgardo, Hanks custodian, TexasJim50, stlcardinalsguy, Woodcmiami, 1 invisible),
57
Mod | | | Forums66 Topics128,059 Posts1,055,820 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Here is a pic of the 2 bolts with bumpers that go on the the lower control arm for my 62 with torsion bar IFS. http://rides.webshots.com/photo/2918644950071636143ZbhDzpThese bolt the inside part of each lower ball joint to the control arm. One of them is fairly shot as I had to heat and remove with a BFH to get it off. Any ideas on where to get this or what I can replace with? Thanks for the help! | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | Bigmacdaddy, I replaced mine either 1 of 2 ways, it's been about 3 years and I can't remember. These are faily common. I remember going to Discount Auto, YES I said Discound auto ans asking for their rubber fittings book, they have it behine the counter, look in the pages by page, and you will usually see them. If not check the same way over at napa. But there out there. Email me direct with your email and I'll see if I can find them for you. These are close but not correct. http://www.rickscamaros.com/product.asp?pf%5Fid=SS%2D11&dept%5Fid=3507 http://www.truckandcarshop.com/trucks60_72/t60_110.htmlJake
